跳转到主内容
Interlink VP4550 Laser Replacement
你所需要的
  1. Interlink VP4550 Laser Replacement, Case: 步骤 1 中的图像 1,3 Interlink VP4550 Laser Replacement, Case: 步骤 1 中的图像 2,3 Interlink VP4550 Laser Replacement, Case: 步骤 1 中的图像 3,3
    • Turn the phone over to where the battery compartment resides.
    • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
    • Remove battery.
  2. Interlink VP4550 Laser Replacement: 步骤 2 中的图像 1,3 Interlink VP4550 Laser Replacement: 步骤 2 中的图像 2,3 Interlink VP4550 Laser Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
    • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
  3. Interlink VP4550 Laser Replacement: 步骤 3 中的图像 1,2 Interlink VP4550 Laser Replacement: 步骤 3 中的图像 2,2
    • There is a wire connector linking the front and the back of the device.
    • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
  4. Interlink VP4550 Laser Replacement: 步骤 4 中的图像 1,2 Interlink VP4550 Laser Replacement: 步骤 4 中的图像 2,2
    • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
    • Find the lever on the right side of the back half of the device.
    • Insert the tip of the lever into the square indent on the underside of the button.
  5. Interlink VP4550 Laser Replacement, Circuit Board: 步骤 5 中的图像 1,1
    • Avoid picking up the front of the device as you work so that loose parts will not shift.
    • Use a Phillips #0 head screwdriver to remove two screws; one on either side of the circuit board.
  6. Interlink VP4550 Laser Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Slide the circuit board down from the tab located underneath the top of the back half
    • The laser is attached to the circuit board and will slide out of its own housing as you slide out the circuit board.
    • Use tweezers to gently remove it if it doesn't come out.
  7. Interlink VP4550 Laser Replacement, Laser: 步骤 7 中的图像 1,1
    • Use desoldering braid to remove the red and black wires attached to both the circuit board and the laser bulb.
    • When you are ready to attach the new laser bulb, use a soldering iron to solder the new bulb's wires to the circuit board.
终点
Alayna Bruney
于02/11/14注册
1 声望
撰写一个指南
团队
Ohio State, Team 1-1, Buehl Spring 2014 Ohio State, Team 1-1, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 183
