跳转到主内容
Interlink VP4550 Case Replacement
你所需要的
  1. Interlink VP4550 Case Replacement, Case: 步骤 1 中的图像 1,3 Interlink VP4550 Case Replacement, Case: 步骤 1 中的图像 2,3 Interlink VP4550 Case Replacement, Case: 步骤 1 中的图像 3,3
    • Turn the phone over to where the battery compartment resides.
    • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
    • Remove battery.
  2. Interlink VP4550 Case Replacement: 步骤 2 中的图像 1,3 Interlink VP4550 Case Replacement: 步骤 2 中的图像 2,3 Interlink VP4550 Case Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
    • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
  3. Interlink VP4550 Case Replacement: 步骤 3 中的图像 1,2 Interlink VP4550 Case Replacement: 步骤 3 中的图像 2,2
    • There is a wire connector linking the front and the back of the device.
    • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
  4. Interlink VP4550 Case Replacement: 步骤 4 中的图像 1,2 Interlink VP4550 Case Replacement: 步骤 4 中的图像 2,2
    • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
    • Find the lever on the right side of the back half of the device.
    • Insert the tip of the lever into the square indent on the underside of the button.
结论
To reassemble your device, follow these instructions in reverse order. It's possible to either use a new case for your phone, or put the old one back on.
另外一个人完成了本指南。
Rachel
于02/12/14注册
1 声望
撰写一个指南
团队
Ohio State, Team 1-1, Buehl Spring 2014 Ohio State, Team 1-1, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G1
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 378
