跳转到主内容
Inter-tel IP 8660 Rear Cover Replacement
你所需要的
  1. Inter-tel IP 8660 Rear Cover Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Rear Cover Replacement: 步骤 2 中的图像 1,3 Inter-tel IP 8660 Rear Cover Replacement: 步骤 2 中的图像 2,3 Inter-tel IP 8660 Rear Cover Replacement: 步骤 2 中的图像 3,3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Rear Cover Replacement: 步骤 3 中的图像 1,1
    • Lift up the back cover and set it aside.
结论
团队
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G24
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 549
