跳转到主内容
Inter-tel IP 8660 Motherboard Replacement
你所需要的
  1. Inter-tel IP 8660 Motherboard Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Motherboard Replacement: 步骤 2 中的图像 1,3 Inter-tel IP 8660 Motherboard Replacement: 步骤 2 中的图像 2,3 Inter-tel IP 8660 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Motherboard Replacement, Internal speaker: 步骤 4 中的图像 1,1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Lift up the speaker.
  6. Inter-tel IP 8660 Motherboard Replacement, LCD Screen: 步骤 6 中的图像 1,3 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: 步骤 6 中的图像 2,3 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: 步骤 6 中的图像 3,3
    • Lift up the motherboard out of its housing in the front cover of the phone.
    • Set the front cover and button pads aside.
  7. Inter-tel IP 8660 Motherboard Replacement: 步骤 7 中的图像 1,3 Inter-tel IP 8660 Motherboard Replacement: 步骤 7 中的图像 2,3 Inter-tel IP 8660 Motherboard Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
    • Note: There are four clips, one at each corner of the LCD screen.
  8. Inter-tel IP 8660 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Flip the motherboard over so that the LCD screen is facing upward.
  9. Inter-tel IP 8660 Motherboard Replacement: 步骤 9 中的图像 1,2 Inter-tel IP 8660 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
    • This is done using the spudger to lift one side out of its housing.
    • Reposition the spudger to the other side of the black clip and push it flush with the other end.
    • Note: The black clip pushes out of the housing and does not come completely loose.
  10. Inter-tel IP 8660 Motherboard Replacement: 步骤 10 中的图像 1,3 Inter-tel IP 8660 Motherboard Replacement: 步骤 10 中的图像 2,3 Inter-tel IP 8660 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Pull gently on the ribbon cable so that it comes loose from the black clip.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G24
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 1,129
