跳转到主内容
配件
没有特定配件。
  1. Disconnect the phone cord from the handset jack.
    • Disconnect the phone cord from the handset jack.
  2. Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head. Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
    • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset. Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
    • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
  5. While holding the handset front cover, grasp and twist the handset microphone and jack until they come free from the cover.
    • While holding the handset front cover, grasp and twist the handset microphone and jack until they come free from the cover.
  6. Unscrew the 2 screws (8 mm long) that hold the receiver in place using a #1 Phillips screwdriver. Note: The screws come with washers. Note: The screws come with washers.
    • Unscrew the 2 screws (8 mm long) that hold the receiver in place using a #1 Phillips screwdriver.
    • Note: The screws come with washers.
  7. Pull the red and green wires that connect the receiver to the microphone out from under the metal piece and black padding. Note: To insert the wires back underneath the black padding, pull the black padding back with your finger and use plastic opening tool to wedge the wires underneath the black padding.
    • Pull the red and green wires that connect the receiver to the microphone out from under the metal piece and black padding.
    • Note: To insert the wires back underneath the black padding, pull the black padding back with your finger and use plastic opening tool to wedge the wires underneath the black padding.
结论
Juan David GutierrezFranco
于2012年01月20日注册
67 信誉积分
创作了4篇指南
团队
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G24
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 883
