跳转到主内容
Inter-tel IP 8660 Button Pad Replacement
你所需要的
  1. Inter-tel IP 8660 Button Pad Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 Button Pad Replacement: 步骤 2 中的图像 1,3 Inter-tel IP 8660 Button Pad Replacement: 步骤 2 中的图像 2,3 Inter-tel IP 8660 Button Pad Replacement: 步骤 2 中的图像 3,3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 Button Pad Replacement: 步骤 3 中的图像 1,1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 Button Pad Replacement, Internal speaker: 步骤 4 中的图像 1,1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 Button Pad Replacement: 步骤 5 中的图像 1,1
    • Lift up the speaker.
  6. Inter-tel IP 8660 Button Pad Replacement, Button Pad: 步骤 6 中的图像 1,1
    • Lift up the motherboard and set aside
  7. Inter-tel IP 8660 Button Pad Replacement: 步骤 7 中的图像 1,1
    • Peel off all rubber button covers.
  8. Inter-tel IP 8660 Button Pad Replacement: 步骤 8 中的图像 1,1
    • Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 11-24, Maness Winter 2012 Cal Poly, Team 11-24, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G24
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 762
