当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
Completely open the gate and remove from camera. Take out the battery and replace the gate.
Turn camera around to its backside.
Open up the back side of the camera by pushing up on the slide button. This button is located on the middle left side of the camera.
Use the Phillips #000 Screwdriver to remove the five 3.5 mm screws located in the backside door of the camera.
Remove the black plastic piece on top, then remove the thin, metal piece. This metal piece is the battery contact.
Replace the battery contact with the new one.
取消:我没有完成这个指南。
2等其他人完成本指南。
与4其他贡献者
于02/28/17注册
690 声望
创作了5篇指南
徽章: 13
+ 10更多徽章
USFT-NANCE-S17S2G1
4 名成员
创作了12篇指南
This guide only removes the battery tray. The contacts are visible in the last pic of the last step, still in place, under the red wire
John Doe - 2023年10月9日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 45
总计 4,321
