跳转到主内容
Instax Mini 90 Battery Contact Replacement
你所需要的
  1. Instax Mini 90 Battery Contact Replacement, Battery: 步骤 1 中的图像 1,2 Instax Mini 90 Battery Contact Replacement, Battery: 步骤 1 中的图像 2,2
    • The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
  2. Instax Mini 90 Battery Contact Replacement: 步骤 2 中的图像 1,2 Instax Mini 90 Battery Contact Replacement: 步骤 2 中的图像 2,2
    • Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
    • Completely open the gate and remove from camera. Take out the battery and replace the gate.
  3. Instax Mini 90 Battery Contact Replacement, Battery Contact: 步骤 3 中的图像 1,3 Instax Mini 90 Battery Contact Replacement, Battery Contact: 步骤 3 中的图像 2,3 Instax Mini 90 Battery Contact Replacement, Battery Contact: 步骤 3 中的图像 3,3
    • Turn camera around to its backside.
    • Open up the back side of the camera by pushing up on the slide button. This button is located on the middle left side of the camera.
  4. Instax Mini 90 Battery Contact Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #000 Screwdriver to remove the five 3.5 mm screws located in the backside door of the camera.
  5. Instax Mini 90 Battery Contact Replacement: 步骤 5 中的图像 1,3 Instax Mini 90 Battery Contact Replacement: 步骤 5 中的图像 2,3 Instax Mini 90 Battery Contact Replacement: 步骤 5 中的图像 3,3
    • Remove the black plastic piece on top, then remove the thin, metal piece. This metal piece is the battery contact.
    • Replace the battery contact with the new one.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S2-G1, Nance Spring 2017 USF Tampa, Team S2-G1, Nance Spring 2017 的会员
USFT-NANCE-S17S2G1
4 名成员
创作了12篇指南
一条评论
This guide only removes the battery tray. The contacts are visible in the last pic of the last step, still in place, under the red wire
John Doe - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 4,398
