跳转到主内容
Instant Pot Smart-60 Plastic Base Replacement
你所需要的
  1. Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: 步骤 1 中的图像 1,2 Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: 步骤 1 中的图像 2,2
    • Take off the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
  2. Instant Pot Smart-60 Plastic Base Replacement: 步骤 2 中的图像 1,1
    • Take out the inner pot and place it somewhere out of the way.
  3. Instant Pot Smart-60 Plastic Base Replacement: 步骤 3 中的图像 1,1
    • Flip the Instant Pot over on its top so that the base is facing upward.
  4. Instant Pot Smart-60 Plastic Base Replacement: 步骤 4 中的图像 1,1
    • Remove the single 12mm Phillips #2 screw holding the base to the device.
  5. Instant Pot Smart-60 Plastic Base Replacement: 步骤 5 中的图像 1,1
    • Rotate the base counter-clockwise, then gently lift the base off of the device.
结论
3等其他人完成本指南。
paola alvarez
于01/24/18注册
534 声望
创作了4篇指南
团队
Cal Poly, Team S1-G4, Livingston Winter 2018 Cal Poly, Team S1-G4, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S1G4
4 名成员
创作了6篇指南
13条评论
Hi, I would like to know, where can I buy a new plastic base? Thank you
nathaliawed - 回复
Hello where can I buy the plastic base
Maureen - 回复
I would like to buy one of these for an 8 Qt model….very hard to source this and terrible customer support as this seems to be a issue for many that burned theirs.
davidghamilton - 回复
Did you ever find out where you can buy this part.
Thank you. Belinda
Belinda Berka - 回复
Do you carry the replacement for this. Thanks
khai01 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 6,658
