跳转到主内容
加入维修社区 - 创建账户
Instant Pot Smart-60 Disassembly
你所需要的
  1. Instant Pot Smart-60 Disassembly, Bottom access plate screw: 步骤 1 中的图像 1,3 Instant Pot Smart-60 Disassembly, Bottom access plate screw: 步骤 1 中的图像 2,3 Instant Pot Smart-60 Disassembly, Bottom access plate screw: 步骤 1 中的图像 3,3
    • Insert wisdom here.
  2. Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: 步骤 2 中的图像 1,3 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: 步骤 2 中的图像 2,3 Instant Pot Smart-60 Disassembly, Bottom bracket - remove battery holder, then 3x bolts: 步骤 2 中的图像 3,3
    • Remove 3x bolts
  3. Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: 步骤 3 中的图像 1,3 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: 步骤 3 中的图像 2,3 Instant Pot Smart-60 Disassembly, Bottom bracket - snap out power receptacle: 步骤 3 中的图像 3,3
  4. Instant Pot Smart-60 Disassembly, Circuit board 1: 步骤 4 中的图像 1,3 Instant Pot Smart-60 Disassembly, Circuit board 1: 步骤 4 中的图像 2,3 Instant Pot Smart-60 Disassembly, Circuit board 1: 步骤 4 中的图像 3,3
    • Black molex connector on top right must come out to remove the outer shell.
    • Red wire spring clips with blue translucent covers I was unable to remove safely, I suggest removing other ends of those wires if you need to remove the heating element plate.
  5. Instant Pot Smart-60 Disassembly, Battery and front panel wires: 步骤 5 中的图像 1,3 Instant Pot Smart-60 Disassembly, Battery and front panel wires: 步骤 5 中的图像 2,3 Instant Pot Smart-60 Disassembly, Battery and front panel wires: 步骤 5 中的图像 3,3
    • I needed small needle nose pliers to pinch and remove wide front panel connector.
  6. Instant Pot Smart-60 Disassembly, Outer shell ground wire: 步骤 6 中的图像 1,3 Instant Pot Smart-60 Disassembly, Outer shell ground wire: 步骤 6 中的图像 2,3 Instant Pot Smart-60 Disassembly, Outer shell ground wire: 步骤 6 中的图像 3,3
  7. Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: 步骤 7 中的图像 1,3 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: 步骤 7 中的图像 2,3 Instant Pot Smart-60 Disassembly, Outer shell removal - release tape from lid sensor wire: 步骤 7 中的图像 3,3
  8. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: 步骤 8 中的图像 1,3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: 步骤 8 中的图像 2,3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire notch: 步骤 8 中的图像 3,3
    • I'm skipping removing heating element and nearby sensors, it's similar to other models. Search for Instant Pot repair videos for instructions.
  9. Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: 步骤 9 中的图像 1,3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: 步骤 9 中的图像 2,3 Instant Pot Smart-60 Disassembly, Outer shell re-assembly - lid sensor wire goes into notch: 步骤 9 中的图像 3,3
  10. Instant Pot Smart-60 Disassembly, Outer shell re-assembly: 步骤 10 中的图像 1,2 Instant Pot Smart-60 Disassembly, Outer shell re-assembly: 步骤 10 中的图像 2,2
    • Pull lid sensor wire up, re-tape to inside of outer shell.
    • Battery replacement, you should remove the screw and pull the mini circuit board holding the battery before attempting to swap batteries.
结论
8等其他人完成本指南。
Zen1
于03/01/18注册
392 声望
撰写一个指南
4指南评论
If the outer shell is dented but panel is functioning is it safe to operate the instant pot? looks like it moved a bit in the box in shipment, no visible damage to the pot just the to the aluminum shell
Jeff Medlin - 回复 分享
Mine is dented and it should be totally fine. As you said, the pressure vessel is separate from the outer shell, so there are no safety concerns. Just asthetic. I wish there wasn't this gap of air between the pressure vessel and the outer shell, or, I wish the shell was a bit more durable as it's VERY easily dented.
Kuake Ye - 回复 分享
What is the voltage of the component named ZNR091
Yanni Koulandris - 回复 分享
I recently used and cleaned my instant pot. After cleaning I found a small spring in the sink. I am wondering if it came from the pot. I have looked at dozens of diagrams and do not see a spring. What are you opinions, safe to use, not safe. Any thoughts ?
Dave - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 42
过去 30 天: 151
总计 9,831
