当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Remove the single T10 Torx screw securing the optical drive fan to the outer case.
Pull the optical drive fan away from the outer case to lift it off the three plastic posts around its perimeter.
Carefully maneuver the optical drive fan out of the iMac, minding any cables that may get caught.
这个步骤还没有翻译 帮忙翻译一下
Remove the six parallel connectors from the top of the logic board using your fingernails, pulling parallel to the logic board.
Skin Temperature
Hard Drive Temperature
Hard Drive Fan
Camera
Bluetooth
Ambient Temperature Sensor
Remove the airport cable from the logic board by prying straight up with a spudger.
这个步骤还没有翻译 帮忙翻译一下
Start leaning the logic board back into the iMac.
Route the SATA data cable underneath the edge of the metal plate behind the logic board.
Continue routing the SATA cable up through the cable slot in the plastic frame.
Finish routing the SATA cable though the cutaway in the plastic frame near the optical drive, just below the GPU heat sink.
114等其他人完成本指南。
27条评论
Adding a SSD drive for the system was a simple process and has completely transformed my old i3 iMac - definitely worth the money and effort
5 hours an IT support officer. This task is not for the feint hearted. A guide from OWC suggested locating SSD near HDD and this proved easier for me. This guide was accurate and the many images were very helpful. Thanks.
Great guide. I followed it but found after removing the logic board there was no secondary sata port!!! Either way I hooked up the original hard drive to power and temp sensor to stop the fan spin up and used the sata for the SSD so works great. One problem! My sound is now greyed out? Any physical reason for this? When the imac powers on it makes a sound but no sounds in Mac OS. I feel it must be physical not software related.
