跳转到主内容
Installing a Metal Snap Using a Hand Press
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Installing a Metal Snap Using a Hand Press, Metal Snap: 步骤 1 中的图像 1,2 Installing a Metal Snap Using a Hand Press, Metal Snap: 步骤 1 中的图像 2,2
    • Get a new stud.
    • Get a new post.
  2. Installing a Metal Snap Using a Hand Press: 步骤 2 中的图像 1,2 Installing a Metal Snap Using a Hand Press: 步骤 2 中的图像 2,2
    • Measure the diameter of the stud and post to make sure they are the correct size. Ours are 1/2".
    • If you're unsure of the correct size, measure a snap on the piece that you are repairing for reference.
  3. Installing a Metal Snap Using a Hand Press: 步骤 3 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 3 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 3 中的图像 3,3
    • Insert the stud into the stud fitting for the hand press. The ridged part should set into the groove on the fitting. When correctly seated, the snap lays flat in the fitting.
    • The stud fitting is marked green.
  4. Installing a Metal Snap Using a Hand Press: 步骤 4 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 4 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 4 中的图像 3,3
    • Insert the post into the post fitting for the hand press. The flat part of the post should sit inside the fitting with the shaft pointed out.
    • The post fitting is marked blue.
  5. Installing a Metal Snap Using a Hand Press: 步骤 5 中的图像 1,2 Installing a Metal Snap Using a Hand Press: 步骤 5 中的图像 2,2
    • Insert the post fitting onto the fitting base of the hand press.
  6. Installing a Metal Snap Using a Hand Press: 步骤 6 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 6 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 6 中的图像 3,3
    • Insert the stud fitting into the upper fitting holder on the hand press.
    • Insert the fitting as far as it will go, so that the only visible part is the wider encasement portion of the fitting.
    • Tighten the screw on the side of the upper fitting holder to secure the stud fitting. Tighten the screw about a 1/4 turn past finger-tight.
  7. Installing a Metal Snap Using a Hand Press: 步骤 7 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 7 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 7 中的图像 3,3
    • Slowly pull the handle on the hand press to test the range of the fittings.
    • The fittings should just touch when the handle is pulled to its maximum.
    • If there is a gap in the fittings, adjust the height of the fitting base on the hand press by turning it until the fittings touch.
  8. Installing a Metal Snap Using a Hand Press: 步骤 8 中的图像 1,2 Installing a Metal Snap Using a Hand Press: 步骤 8 中的图像 2,2
    • Mark the fabric where you will be inserting the snap.
    • Align the fabric in the hand press so that the mark rests directly above the shaft of the post.
    • If the fabric is not laying flat, have a friend pull the fabric taut to help keep it flat as you insert the snap.
  9. Installing a Metal Snap Using a Hand Press: 步骤 9 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 9 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 9 中的图像 3,3
    • With the fabric aligned, pull the handle of the hand press down in one continuous motion.
    • Apply pressure until you feel the snap give.
    • Setting a metal snap requires force. You will need to pull hard.
  10. Installing a Metal Snap Using a Hand Press: 步骤 10 中的图像 1,2 Installing a Metal Snap Using a Hand Press: 步骤 10 中的图像 2,2
    • Release the handle of the hand press, and remove the fabric.
    • Inspect both sides of your snap to make sure that it is laying flat and tight up against the fabric.
    • If the snap is not set all the way, reinsert the snap into the hand press, aligning it as it was before, and repeat step 9 of this guide.
  11. Installing a Metal Snap Using a Hand Press: 步骤 11 中的图像 1,2 Installing a Metal Snap Using a Hand Press: 步骤 11 中的图像 2,2
    • Get a new cap.
    • Get a new socket.
  12. Installing a Metal Snap Using a Hand Press: 步骤 12 中的图像 1,2 Installing a Metal Snap Using a Hand Press: 步骤 12 中的图像 2,2
    • Measure the diameter of the components to ensure that they are the correct size. These are 1/2" in diameter.
    • If you are unsure of the correct size, measure a snap on the piece that you are repairing for reference.
  13. Installing a Metal Snap Using a Hand Press: 步骤 13 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 13 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 13 中的图像 3,3
    • Insert the cap, shaft facing out, into the cap fitting for the hand press. When correctly seated, the cap should not extend beyond the fitting.
    • The cap fitting is marked orange.
  14. Installing a Metal Snap Using a Hand Press: 步骤 14 中的图像 1,2 Installing a Metal Snap Using a Hand Press: 步骤 14 中的图像 2,2
    • Insert the socket into the socket fitting for the hand press. Place the widest part of the socket facing the fitting. When correctly seated, the socket will snap on to the fitting and sit without being held.
    • The socket fitting is marked in purple.
  15. Installing a Metal Snap Using a Hand Press: 步骤 15 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 15 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 15 中的图像 3,3
    • Insert the cap fitting onto the fitting base of the hand press.
    • The cap fitting is marked in orange.
  16. Installing a Metal Snap Using a Hand Press: 步骤 16 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 16 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 16 中的图像 3,3
    • Insert the socket fitting into the upper fitting holder on the hand press.
  17. Installing a Metal Snap Using a Hand Press: 步骤 17 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 17 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 17 中的图像 3,3
    • Be careful to not let the handle flip back and hit you in the face.
  18. Installing a Metal Snap Using a Hand Press: 步骤 18 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 18 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 18 中的图像 3,3
    • The cap is on the bottom of the press. Be sure that you place your fabric face down, so that the cap is on the correct side.
  19. Installing a Metal Snap Using a Hand Press: 步骤 19 中的图像 1,3 Installing a Metal Snap Using a Hand Press: 步骤 19 中的图像 2,3 Installing a Metal Snap Using a Hand Press: 步骤 19 中的图像 3,3
  20. Installing a Metal Snap Using a Hand Press: 步骤 20 中的图像 1,2 Installing a Metal Snap Using a Hand Press: 步骤 20 中的图像 2,2
    • If the snap is not set all the way, reinsert the snap into the hand press, aligning it as it was before, and repeat step 19 of this guide.
结论
Admire your handiwork!
Brittany McCrigler
于03/05/12注册
90,475 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 89
