跳转到主内容
Installing Mac mini Mid 2010 Dual Drive
你所需要的
  1. Installing Mac mini Mid 2010 Dual Drive, Bottom Cover: 步骤 1 中的图像 1,2 Installing Mac mini Mid 2010 Dual Drive, Bottom Cover: 步骤 1 中的图像 2,2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
  2. Installing Mac mini Mid 2010 Dual Drive: 步骤 2 中的图像 1,1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Installing Mac mini Mid 2010 Dual Drive, Fan: 步骤 3 中的图像 1,1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Installing Mac mini Mid 2010 Dual Drive: 步骤 4 中的图像 1,1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
  5. Installing Mac mini Mid 2010 Dual Drive: 步骤 5 中的图像 1,1
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
    • Remove the fan.
  6. Installing Mac mini Mid 2010 Dual Drive, Cowling: 步骤 6 中的图像 1,1
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Installing Mac mini Mid 2010 Dual Drive: 步骤 7 中的图像 1,1
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Installing Mac mini Mid 2010 Dual Drive, Antenna Plate: 步骤 8 中的图像 1,1
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 or T9 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
  9. Installing Mac mini Mid 2010 Dual Drive: 步骤 9 中的图像 1,2 Installing Mac mini Mid 2010 Dual Drive: 步骤 9 中的图像 2,2
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate straight away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Installing Mac mini Mid 2010 Dual Drive: 步骤 10 中的图像 1,1
    • Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
  11. Installing Mac mini Mid 2010 Dual Drive: 步骤 11 中的图像 1,1
    • Remove the antenna plate from the mini.
  12. Installing Mac mini Mid 2010 Dual Drive, Logic Board: 步骤 12 中的图像 1,1
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  13. Installing Mac mini Mid 2010 Dual Drive: 步骤 13 中的图像 1,2 Installing Mac mini Mid 2010 Dual Drive: 步骤 13 中的图像 2,2
    • Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
  14. Installing Mac mini Mid 2010 Dual Drive: 步骤 14 中的图像 1,2 Installing Mac mini Mid 2010 Dual Drive: 步骤 14 中的图像 2,2
    • Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
  15. Installing Mac mini Mid 2010 Dual Drive: 步骤 15 中的图像 1,1
    • To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
  16. Installing Mac mini Mid 2010 Dual Drive: 步骤 16 中的图像 1,1
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
  17. Installing Mac mini Mid 2010 Dual Drive: 步骤 17 中的图像 1,3 Installing Mac mini Mid 2010 Dual Drive: 步骤 17 中的图像 2,3 Installing Mac mini Mid 2010 Dual Drive: 步骤 17 中的图像 3,3
    在这个步骤中使用的工具:
    Mac mini Logic Board Removal Tool
    • To remove the logic board, two cylindrical rods must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
    • If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
  18. Installing Mac mini Mid 2010 Dual Drive: 步骤 18 中的图像 1,1
    • Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
  19. Installing Mac mini Mid 2010 Dual Drive: 步骤 19 中的图像 1,1
    在这个步骤中使用的工具:
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use a pair of tweezers to disconnect the power cable from the logic board.
    • Pull the power cable connector toward the optical drive opening.
  20. Installing Mac mini Mid 2010 Dual Drive: 步骤 20 中的图像 1,1
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
  21. Installing Mac mini Mid 2010 Dual Drive, Power Supply: 步骤 21 中的图像 1,1
    • Remove the 7.9 mm T6 Torx screw securing the power supply and optical drive to the outer case.
  22. Installing Mac mini Mid 2010 Dual Drive: 步骤 22 中的图像 1,2 Installing Mac mini Mid 2010 Dual Drive: 步骤 22 中的图像 2,2
    • Pull the silver metal AC-In socket retainer away from the side of the outer case and remove it from the mini.
  23. Installing Mac mini Mid 2010 Dual Drive: 步骤 23 中的图像 1,2 Installing Mac mini Mid 2010 Dual Drive: 步骤 23 中的图像 2,2
    • Rotate the AC-In connector 90 degrees counter-clockwise.
  24. Installing Mac mini Mid 2010 Dual Drive: 步骤 24 中的图像 1,1
    • Slide the power supply out of the mini, minding any cables that may get caught.
  25. Installing Mac mini Mid 2010 Dual Drive, Optical Drive: 步骤 25 中的图像 1,1
    • Remove the hard drive from the mini, minding any cables that may get caught.
  26. Installing Mac mini Mid 2010 Dual Drive: 步骤 26 中的图像 1,1
    • Remove the 7.9 mm T6 Torx screw securing the optical drive to the outer case.
  27. Installing Mac mini Mid 2010 Dual Drive: 步骤 27 中的图像 1,1
    • Slide the optical drive out of the outer case, minding any cables that may get caught.
  28. Installing Mac mini Mid 2010 Dual Drive, Optical Drive: 步骤 28 中的图像 1,1
    • Carefully de-route the IR sensor cables from the channel in the optical drive bracket.
  29. Installing Mac mini Mid 2010 Dual Drive: 步骤 29 中的图像 1,2 Installing Mac mini Mid 2010 Dual Drive: 步骤 29 中的图像 2,2
    • Remove the two 6.3 mm T6 Torx screws securing both sides of the optical drive bracket to the optical drive (four screws total).
  30. Installing Mac mini Mid 2010 Dual Drive: 步骤 30 中的图像 1,1
    • Remove the optical drive bracket from the optical drive, minding any cables that may get caught.
  31. Installing Mac mini Mid 2010 Dual Drive: 步骤 31 中的图像 1,1
    • Carefully peel the optical drive ribbon cable off the body of the optical drive.
  32. Installing Mac mini Mid 2010 Dual Drive: 步骤 32 中的图像 1,1
    • Disconnect the optical drive cable by pulling its connector away from the body of the optical drive.
  33. Installing Mac mini Mid 2010 Dual Drive: 步骤 33 中的图像 1,1
    • Peel off the strip of black tape covering the optical drive thermal sensor.
  34. Installing Mac mini Mid 2010 Dual Drive: 步骤 34 中的图像 1,1
    • Carefully pry the optical drive thermal sensor off the adhesive securing it to the optical drive.
    • It may be necessary to use a strip of tape or rubber cement to attach the thermal sensor to your new optical drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  35. Installing Mac mini Mid 2010 Dual Drive, Dual Hard Drive: 步骤 35 中的图像 1,2 Installing Mac mini Mid 2010 Dual Drive, Dual Hard Drive: 步骤 35 中的图像 2,2
    • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  36. Installing Mac mini Mid 2010 Dual Drive: 步骤 36 中的图像 1,3 Installing Mac mini Mid 2010 Dual Drive: 步骤 36 中的图像 2,3 Installing Mac mini Mid 2010 Dual Drive: 步骤 36 中的图像 3,3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  37. Installing Mac mini Mid 2010 Dual Drive: 步骤 37 中的图像 1,2 Installing Mac mini Mid 2010 Dual Drive: 步骤 37 中的图像 2,2
    • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
结论
83等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
90,418 声望
创作了142篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,608篇指南
15指南评论
I've run through this tutorial twice. First time I switched our the HDD for a 1tb, and the DVD drive for an SSD. The HDD works but the machine didn't find the SSD. I then swapped them - it now finds the SSD but not in the HDD which is now in what used to be the optical drive slot.
Do I need to buy a new cable for the optical drive? As it appears that's what it's not reading, or is there something I've missed?
Thanks
Josh G - 回复
You need to go to Disk Utility and format the SSD/Hard Drive.
- PS5iscool - -
Just completed this in under an hour, thanks in part to reading the whole guide once over before and reading all the comments about the various different steps, so thanks also to the commenters!
Amazingly, system booted first time and it sees the 2nd HDD (SSD actually), now to try setting up a Fusion drive :-)
Simon Martin - 回复
I did it! With lots of help from my friends who work at an apple repair store... perhaps that is cheating?
I too am having trouble now with the disk utility recognizing the newly installed hard drive. Did I miss something? I followed the instructions perfectly. And my repair friends helped me with the "why won't this fit back together you tiny unibody you!"
Any suggestions for how to get the disk utility to recognize my drive I just worked so hard to put in there would be greatly appreciated!
kmvbconover - 回复
achtet auf die Bauhöhe der Festplatte! Man bekommt zwar eine 12,1 mm hohe Platte rein, aber es wird alles mehr als eng
dirkmutik - 回复
添加评论
浏览统计数据:
过去 24 小时: 86
过去 7 天: 664
过去 30 天: 1,599
总计 96,140
