当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Using a seam ripper, gently remove the stitches on the inside of the zipper.
Be careful not to accidentally puncture or tear the jacket.
Bend the zipper teeth away from the zipper webbing to make it easier to reach the stitches that hold the zipper and webbing together.
Using the seam ripper, gently rip the seam between the zipper and zipper webbing.
Identify where the zipper flap is still sewn into the jacket. Use the seam ripper to free the zipper flap from the jacket. The yellow rectangle in the photos above will help you identify the zipper flap.
Be careful not to damage the jacket with the seam ripper as you free the webbing.
Lay the jacket flat and measure from the base of the zipper to the collar, along the seam you just removed. In our case we measured 27 inches.
The jacket should be flat, so you get an accurate measurement.
Lay out your new zipper on a flat surface and use the measurement you recorded in the step above, starting from the zipper box, or the bottom of the zipper.
Mark the measurement with tailor's chalk.
Pull the zipper slider back behind the mark you just made.
Take a zipper stop and align it, posts down, just beyond the last remaining zipper tooth.
Crimp the zipper stop onto the zipper using pliers.
Fold the excess zipper tape away from the teeth at a slight angle.
Sew the toothless end of the zipper down, backstitching to hold it in place.
Align the toothless edge of the zipper with the inside serged edge of the zipper webbing.
The serged edge is the one with the zig-zag stitching.
Fold the top of the webbing down over the sewn zipper tape.
You can pin the zipper and webbing in place for more stability.
Align the zipper and webbing in the sewing machine so that the zipper teeth are along the edge of the presser foot.
Sew a few stitches, removing pins before you come to them.
Install the zipper foot into your sewing machine.
Align the jacket and zipper in the sewing machine.
Be sure that there is no fabric behind the zipper webbing before you sew.
Check your alignment and begin sewing, guiding the fabric along the zipper teeth.
Go slowly, re-aligning the fabric as you go.
Align the jacket in the sewing machine, with the zipper webbing facing up.
Holding the inside fabric of the jack in place, sew directly over the original stitching.
Clip the threads, and admire your work!
Repeat this guide, ironing the webbing when you’re finished, to install the other side of the zipper.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
