跳转到主内容
Installation/Removal of the WIC/HWIC card
精选文档
  1. Installation/Removal of the WIC/HWIC card, Turn the equipment off: 步骤 1 中的图像 1,1
    • In order to install or remove a card the equipment should be turned off.
  2. Installation/Removal of the WIC/HWIC card, Remove the port covers on the EHWIC: 步骤 2 中的图像 1,3 Installation/Removal of the WIC/HWIC card, Remove the port covers on the EHWIC: 步骤 2 中的图像 2,3 Installation/Removal of the WIC/HWIC card, Remove the port covers on the EHWIC: 步骤 2 中的图像 3,3
    • Loosen the cards' screws.
    • Do not remove them completely. Once they are loose the spring will push the screw outwards.
    • To remove, pull on the card.
    • It is recommended that you clean the card of dust.
  3. Installation/Removal of the WIC/HWIC card, Insert the card: 步骤 3 中的图像 1,2 Installation/Removal of the WIC/HWIC card, Insert the card: 步骤 3 中的图像 2,2
    • Insert the card or install the protective router cover to avoid dust accumulation.
结论
To re-assemble your device, follow these instructions in reverse.
另外一个人完成了本指南。
由衷感谢以下译者:
es en
100%
WhoDat?正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Eneider Colina
于09/20/13注册
2,370 声望
创作了9篇指南
团队
Comunidad para traductores de español Comunidad para traductores de español 的会员
Community
29 名成员
创作了334篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 40
总计 913
