跳转到主内容
加入维修社区 - 创建账户
Install an Extension Cord Female Plug
你所需要的
  1. Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: 步骤 1 中的图像 1,3 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: 步骤 1 中的图像 2,3 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: 步骤 1 中的图像 3,3
    • Install an Extension Cord Female Plug is a relatively simple process that anyone can do at home. This is the cord that we will repair.
    • Disconnect the cable before carrying out any repair work.
    • Use a utility knife to cleanly cut from the middle and around the cable.
  2. Install an Extension Cord Female Plug: 步骤 2 中的图像 1,3 Install an Extension Cord Female Plug: 步骤 2 中的图像 2,3 Install an Extension Cord Female Plug: 步骤 2 中的图像 3,3
    • Use wire strippers to remove about 2 cm from the inner wires
  3. Install an Extension Cord Female Plug: 步骤 3 中的图像 1,2 Install an Extension Cord Female Plug: 步骤 3 中的图像 2,2
    • Make sure you put the bottom cover of the female plug.
  4. Install an Extension Cord Female Plug: 步骤 4 中的图像 1,3 Install an Extension Cord Female Plug: 步骤 4 中的图像 2,3 Install an Extension Cord Female Plug: 步骤 4 中的图像 3,3
    • The green screw is for the (green wire), the gold screw is for the (black wire), and the silver screw is for the (white wire).
    • For green wire.
    • For black wire
    • For white wire.
    • Now when you have each wire inside the hole you tighten the three screws.
  5. Install an Extension Cord Female Plug: 步骤 5 中的图像 1,3 Install an Extension Cord Female Plug: 步骤 5 中的图像 2,3 Install an Extension Cord Female Plug: 步骤 5 中的图像 3,3
    • Electrical tape is optional.
    • Need to make sure both of the parts are lined up in the same directions.
    • Push both parts together and you would see the screws pop up.
  6. Install an Extension Cord Female Plug: 步骤 6 中的图像 1,3 Install an Extension Cord Female Plug: 步骤 6 中的图像 2,3 Install an Extension Cord Female Plug: 步骤 6 中的图像 3,3
    • Tightening the top three screws.
    • Also, need to tighten the two bottom screws.
    • Make sure you have one or two fingers in the back of the two screws so they pop up.
  7. Install an Extension Cord Female Plug: 步骤 7 中的图像 1,1
    • Test out.
结论
2等其他人完成本指南。
团队
CSU Los Angeles, Team 5-20, Kershman Fall 2023 CSU Los Angeles, Team 5-20, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S5G20
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 110
总计 1,534
