跳转到主内容
Install Series 2 Display on a Series 3 with Apple Pay
你所需要的
  1. Install Series 2 Display on a Series 3 with Apple Pay, Meet the patient: 步骤 1 中的图像 1,1
    • Here we have a Series 3 Apple Watch with a broken Display.
    • Sad.
  2. Install Series 2 Display on a Series 3 with Apple Pay, Open 'er up: 步骤 2 中的图像 1,1
    • Remove the broken Display. The worse they're busted up, the easier they come off!
    • Remove any adhesive residue and tape from the Force Touch Sensor, and inspect it for damage. Replace if necessary.
  3. Install Series 2 Display on a Series 3 with Apple Pay, Prepare the donor: 步骤 3 中的图像 1,1
    • The right-hand module contains the NFC and Light Sensor. It's attached by some adhesive dots, two solder bumps (for the NFC antenna connection), and some copper tape.
    • Cut the copper tape from the NFC module.
  4. Install Series 2 Display on a Series 3 with Apple Pay, Save the NFC, save the world: 步骤 4 中的图像 1,3 Install Series 2 Display on a Series 3 with Apple Pay, Save the NFC, save the world: 步骤 4 中的图像 2,3 Install Series 2 Display on a Series 3 with Apple Pay, Save the NFC, save the world: 步骤 4 中的图像 3,3
    • Using an Xacto #17 blade, chisel the NFC module from the damaged Display.
    • Keep the blade as parallel as possible to the Display.
  5. Install Series 2 Display on a Series 3 with Apple Pay, Successful donation: 步骤 5 中的图像 1,3 Install Series 2 Display on a Series 3 with Apple Pay, Successful donation: 步骤 5 中的图像 2,3 Install Series 2 Display on a Series 3 with Apple Pay, Successful donation: 步骤 5 中的图像 3,3
    • Now the NFC module is free. There's some tape on the back of the module; you can peel it off with tweezers.
    • You can see there are two solder bumps under here. These are the connections to the NFC antenna.
    • If you use alcohol or some other solvent to help clean up, use it very sparingly. We don't want to mess up the Light Sensor.
  6. Install Series 2 Display on a Series 3 with Apple Pay, Meet the New Guy: 步骤 6 中的图像 1,2 Install Series 2 Display on a Series 3 with Apple Pay, Meet the New Guy: 步骤 6 中的图像 2,2
    • Here is a "new" (probably harvested) Series 2 Display I bought online. I marked it with a "2" just because.
    • Remove the NFC module from this display. You can discard it or sprinkle it on your breakfast cereal.
    • I got a little over-aggressive taking this off so you can see I removed some of the black tape covering the NFC antenna. No harm done, though, and it let me show a corner of the NFC antenna.
  7. Install Series 2 Display on a Series 3 with Apple Pay, A sticky situation: 步骤 7 中的图像 1,1
    • Now we apply a bit of "Z Tape" to the back of the module. Z Tape is nifty stuff that conducts electricity through its thickness but not sideways.
    • In this photo the release layer is still on the Z tape. We'll take it off before sticking the module onto the Series 2 Display.
    Where do I purchase this magical Z Tape? I can’t find it anywhere under that name
    Jared Tamana (Sean) - 回复
    Adafruit sells small pieces of the magical "Z-tape": https://www.adafruit.com/product/1656 this way you don't have to buy a $75 roll of 3M z-axis conductive tape.
    Stefan Mullikin -
    Look for 3M Z-axis Electrically Conductive Tape. Looks like its about $75/roll :/
    Stefan Mullikin - 回复
  8. Install Series 2 Display on a Series 3 with Apple Pay, Frankenstein's Monster: 步骤 8 中的图像 1,1
    • Yup, that's our Series 2 Display with the NFC module from the broken S3 Display attached. Alignment here is fairly important so don't just slap it on all willy-nilly.
  9. Install Series 2 Display on a Series 3 with Apple Pay, Reprogramming: 步骤 9 中的图像 1,1
    • Sometimes it just works, and sometimes you need to reflash the OS to make everyone play nice together. Good luck finding the magic IPSW files.
    How likely is it that the watch will need reflashing? Is it an incompatibility with a series 2 screen that you are getting around or is it an NFC change that would need doing with the series 3 as well? At home repairer, can’t afford the iBUS….
    Harry - 回复
    I’m not sure what the issue is; sometimes I noticed that Force Touch didn’t work after a Display replacement (?!) and reflashing made it work again. But sometimes reflashing wasn’t necessary. Since I had the iBus, I just reflashed as a matter of course. There seem to be some dark ninja-like corners to the Apple Watch firmware.
    Gordon Hlavenka - 回复
    Have you tried this swop with a series 4 ?
    markbellgb - 回复
  10. Install Series 2 Display on a Series 3 with Apple Pay, It works!: 步骤 10 中的图像 1,1
    • After all this, Apple Pay can be configured on the Watch and you can see that it talks to the NXP TagInfo app.
    • I had to use an Android phone to test the NFC because Apple doesn't let apps get deep enough into iPhone's NFC to read this stuff.
    Hi Gordon,
    first of all thank you for your detailed walkthrough. I was able to follow the steps above and finally want to test the NFC module on the Watch i worked on.
    Can you please share some details on which software you used on the Android phone to simulate a NFC signal triggering the watch and Apple Pay?
    Thanks
    franqus - 回复
    That app he used is called NFC TagInfo by NXP
    Aydan -
终点
16等其他人完成本指南。
13条评论
This is one of those guides that goes above and beyond. Now can you tell us how to flash the software?
fdsajky675 - 回复
viarengo1 - The tricky part of reflashing is actually just getting the IPSW files to flash — OTA update files don’t work and Apple doesn’t release the complete files. If you can manage to get the file, though, you connect the Watch to a programming adapter (either iBus or the Apple adapter), load iTunes, and the Watch shows up. Then you shift-click on Restore, point to your hard-won IPSW, and off you go. You can sometimes find Apple programming adapters on eBay and MFCBox sells the iBus, which is a clone of the Apple adapter. But the IPSW files are a major PITA. Right now I don’t think any of them are in the wild except WatchOS 4.3.1 for Series 3 only.
There are plenty of ipsws for Apple Watch on ipsw.me. Are they usable?
IO -
IO - No, the ipsws on ipsw.me and similar sites won’t work. They are over-the-air update files (“OTA”) and do not contain a complete set of code including boot loader and all modules.
Hi mate, swapped numerous series 3 working screens and their NFC chips as shown in the article. Works perfectly and contactless sets up with no problems. Even when double clicking the side the ‘ready’ message appears. However when bringing the watch near the card reader it fails to communicate, nothing happens. Any ideas what to do? Thanks!
Mr Hawaii - 回复
Could you use the GPS only module on one of these displays? My watch is not the LTE version but the GPS only display is not available anywhere that I can find.
Amy jo cooper - 回复
What if I install a new series 3 screen do i need to take the nfc from the old screen still and install on the new one?
Duan Peters - 回复
So you want to install a Series 3 screen on a Series 2 body? Maybe this vice versa guide might help you: Install Series 2 Display on a Series 3 with Apple Pay
Tobias Isakeit -
Could you please explain how to reflash the OS?
Derek Miller - 回复
Does this guide still work? (Does it work for newer Generations as well?)
And Can the NFC Chip from the broken AWS3 Screen be applied to a working AWS3 Screen?
Alexander Laxgang - 回复
I’m okay with no Apple Pay.
If I removed the NFC module, and didn’t replace it, what would happen? Would it still overheat and have poor battery life? Or would it bootloop, even? 🤔
Koston Morin - 回复
You can buy smaller pieces of 3M Z-axis Tape aka Z tape from Adafruit: https://www.adafruit.com/product/1656 Enjoy!
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 96
总计 19,800
