跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Caution
This guide instructs you to defeat a stock security feature that prevents your Android device from installing applications from unknown sources.
What this means: without this security protection, third party web sites can download and attempt to install malware or hacks that compromise your system, steal your data, even steal your identity.
Exercise due caution when disabling this setting.
Version
This guide uses screenshots from Android 6.0.1 (Marshmellow). Depending upon your device's version of Android (including manufacturer's changes), your screens may appear differently.
  1. Click the App Drawer icon on your home screen. Generally this is at the bottom, in the middle. Open your Settings in your device.
    • Click the App Drawer icon on your home screen. Generally this is at the bottom, in the middle.
    • Open your Settings in your device.
  2. Select the setting called Security. If security isn't there, you may need to open the More tab.
    • Select the setting called Security.
    • If security isn't there, you may need to open the More tab.
    • The Security settings screen opens.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Click on the check box next to "Install from unknown sources" to allow it. You will see a security prompt explaining how installation from the internet or your sd card can be dangerous sometimes.
    • Click on the check box next to "Install from unknown sources" to allow it.
    • You will see a security prompt explaining how installation from the internet or your sd card can be dangerous sometimes.
    • Read this warning. You are disabling a security feature of Android that protects your device from potential malware. Do so with caution.
    • Click OK in the prompt to acknowledge and accept the change.
  5. You have successfully enabled the Unknown Sources installation option of Android.
    • You have successfully enabled the Unknown Sources installation option of Android.
    • In addition to installing apps from third parties (non-Play store), you can install .APK installers from your device's file system.
结论
To disable the changes, turn the "Unknown Sources" setting back to OFF.
36等其他人完成本指南。
Mod King Bro
于2016年01月28日注册
489 信誉积分
撰写一个指南
Thanks man!
Always good to clarify.
Johnny Fandry - 回复
Thanks
It donne
This is so easy
CX7 tube - 回复
i have one app deploy then mention the step wise how to install ? this guideline how to apply
dhanshriautade - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 38
过去的30天: 199
总计 3,303
