跳转到主内容
Inspiron 7359 2-in-1 Fan Replacement
你所需要的
  1. Inspiron 7359 2-in-1 Fan Replacement, Disassembling the Inspiron 7359 2-in-1: 步骤 1 中的图像 1,1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Fan Replacement: 步骤 2 中的图像 1,2 Inspiron 7359 2-in-1 Fan Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Fan Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Fan Replacement: 步骤 4 中的图像 1,1
    • All hardware components should be exposed.
  5. 注意:步骤 5-6 源自标记为进行中的 指南
    Inspiron 7359 2-in-1 Fan Replacement, Hard Disk Drive: 步骤 5 中的图像 1,1
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Fan Replacement: 步骤 6 中的图像 1,2 Inspiron 7359 2-in-1 Fan Replacement: 步骤 6 中的图像 2,2
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
  7. Inspiron 7359 2-in-1 Fan Replacement, Fan: 步骤 7 中的图像 1,2 Inspiron 7359 2-in-1 Fan Replacement, Fan: 步骤 7 中的图像 2,2
    • Carefully pull the fan adapter labelled one.
  8. Inspiron 7359 2-in-1 Fan Replacement: 步骤 8 中的图像 1,1
    • Pull the wire from the hook to make it easier to take the whole fan out.
  9. Inspiron 7359 2-in-1 Fan Replacement: 步骤 9 中的图像 1,1
    • Remove one 5mm screw using the Phillips screw.
    • After the screw is extracted use your hands and carefully take the fan out.
结论
Dominique
于08/26/19注册
251 声望
创作了2篇指南
团队
Gateway, Team S1-G3, Saknee Fall 2019 Gateway, Team S1-G3, Saknee Fall 2019 的会员
GCC-SAKNEE-F19S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 449
