跳转到主内容
Insignia Sport NS-4V17 Motherboard Replacement
你所需要的
  1. Insignia Sport NS-4V17 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Motherboard Replacement: 步骤 2 中的图像 1,2 Insignia Sport NS-4V17 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Motherboard Replacement, Front Case Cover: 步骤 5 中的图像 1,2 Insignia Sport NS-4V17 Motherboard Replacement, Front Case Cover: 步骤 5 中的图像 2,2
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Motherboard Replacement: 步骤 7 中的图像 1,3 Insignia Sport NS-4V17 Motherboard Replacement: 步骤 7 中的图像 2,3 Insignia Sport NS-4V17 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  9. Insignia Sport NS-4V17 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Remove the white plastic ring from around the scroll wheel with your fingers.
  10. Insignia Sport NS-4V17 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Hold the sides of the device firmly with one hand.
    • Push down on the black favorite switch with your other hand so that it is pushed into the case.
  11. Insignia Sport NS-4V17 Motherboard Replacement: 步骤 11 中的图像 1,2 Insignia Sport NS-4V17 Motherboard Replacement: 步骤 11 中的图像 2,2
    • With the component pushed in, lift up the top of the motherboard from the case.
    • Pull the motherboard from the top so that the audio jack and usb input are removed from the case socket.
结论
另外一个人完成了本指南。
Wesley Ballar
于04/18/13注册
88 声望
创作了4篇指南
团队
Cal Poly, Team 12-36, Amido Spring 2013 Cal Poly, Team 12-36, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G36
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 479
