跳转到主内容
Insignia NSD9PDVD15 Screen Replacement
你所需要的
  1. Insignia NSD9PDVD15 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Insignia NSD9PDVD15 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Slide the “Open” tab on the top of the device.
    • This will allow you to open the device.
  2. Insignia NSD9PDVD15 Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the six Phillips #00 screws from the screen casing.
    • To access two of the screws, first remove 2 small, flat rubber circles from the corners of the screen casing. Use a spudger if necessary.
  3. Insignia NSD9PDVD15 Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws from the hinge that holds together the screen casing and the disk panel.
    • Abruptly opening the device too wide will break the hinge. To fully access the hinge screws, firmly but gently open the device wider.
  4. Insignia NSD9PDVD15 Screen Replacement: 步骤 4 中的图像 1,1
    • Insert the plastic opening tool into the rectangular holes and pry open in order to access the interior of the screen casing.
    • Remove the four screws and corresponding washers from the edges of the screen.
    • Use a plastic opening tool to prop open if necessary.
  5. Insignia NSD9PDVD15 Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the eight screws from the green motherboard.
  6. Insignia NSD9PDVD15 Screen Replacement: 步骤 6 中的图像 1,1
    • Unplug the red wires from the motherboard by gently pulling them off.
    • Then remove the screen.
  7. Insignia NSD9PDVD15 Screen Replacement: 步骤 7 中的图像 1,1
    • Set the new screen in place.
结论
Jen Rodas
于09/30/15注册
1 声望
撰写一个指南
团队
Ohio State, Team 2-5, Garvin Fall 2015 Ohio State, Team 2-5, Garvin Fall 2015 的会员
OSU-GARVIN-F15S2G5
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 457
