简介
The Insignia 2-in-1 stick vacuum power button can suddenly stop working or become jammed. In either case, use this guide to fix or replace the power button.
你所需要的
Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle.
Pull up on the back cover of the vacuum handle and remove it.
即将完成!
结论
