跳转到主内容
Insignia NS-VCS14SL7 Power Button Replacement
你所需要的
  1. Insignia NS-VCS14SL7 Power Button Replacement, Battery: 步骤 1 中的图像 1,2 Insignia NS-VCS14SL7 Power Button Replacement, Battery: 步骤 1 中的图像 2,2
    • Push down the black button to release the dust cup.
    • Pull the dust cup up and away from handheld portion to remove.
  2. Insignia NS-VCS14SL7 Power Button Replacement: 步骤 2 中的图像 1,3 Insignia NS-VCS14SL7 Power Button Replacement: 步骤 2 中的图像 2,3 Insignia NS-VCS14SL7 Power Button Replacement: 步骤 2 中的图像 3,3
    • Remove the five 12.0 mm screws on the back of the handheld portion using the Phillips #2 screwdriver.
    • Lift the silver cover off of the black body of the handheld portion to expose the battery and wiring.
  3. Insignia NS-VCS14SL7 Power Button Replacement: 步骤 3 中的图像 1,2 Insignia NS-VCS14SL7 Power Button Replacement: 步骤 3 中的图像 2,2
    • Pull apart the red and black wires.
    • Do so for all of the wires. (Red x1, Black x2)
  4. Insignia NS-VCS14SL7 Power Button Replacement: 步骤 4 中的图像 1,1
    • Remove the tape holding the battery to the black housing.
    • Slide the entire battery bundle out.
  5. Insignia NS-VCS14SL7 Power Button Replacement, Handheld Vacuum Power Button: 步骤 5 中的图像 1,1
    • Remove motor and impeller housing to gain access to power button.
  6. Insignia NS-VCS14SL7 Power Button Replacement: 步骤 6 中的图像 1,2 Insignia NS-VCS14SL7 Power Button Replacement: 步骤 6 中的图像 2,2
    • Pry upwards on the retaining clip with black plastic spudger and pull to remove the 5 pin connector.
  7. Insignia NS-VCS14SL7 Power Button Replacement: 步骤 7 中的图像 1,2 Insignia NS-VCS14SL7 Power Button Replacement: 步骤 7 中的图像 2,2
    • Remove the two 10mm Philips #2 screws holding the brown printed circuit board to the vacuum.
    • Remove brown printed circuit board.
    • Pull up on clear plastic power button assembly to remove.
结论
Thibaut Pillot
于02/15/18注册
434 声望
创作了5篇指南
团队
USF Tampa, Team S16-G3, Boczar Spring 2018 USF Tampa, Team S16-G3, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S16G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 229
