简介
The rear panel must be removed in order to repair or replace internal components. Using the metal tool helps in removal because the speaker is metal and a plastic tool would likely break with the force required to remove the panel.
你所需要的
Be sure the radio is turned off by pressing the red power button.
Or, if using the charger, remove the power cord.
Using the J1 Philip's head screwdriver, remove the 4 screws from the back side of the radio.
2条评论
I am having a problem with getting a solid left/right sound connection when using the headphone input with my Aux cord. I know it’s the input, and not my cord because the cord works fine on other applications. You must wiggle the cord once inserted to get both channels to play sound. I believe that the internal contacts on the female headphone port are bent and are not making full contact with the male portion of the plug. If I follow your instructions on removing the back panel, is this an easy task to fix? This is the Model:NS-HDRAD2 which I think may be a little different based on inputs, but overall appears to be same regarding panel removal. you may email me at jeffksbr@mail.com You have a great site with great instructions. Thank you so much!
Does anyone know the size in MM of the power plug in?
Thanks
