跳转到主内容
Insignia NS-F12R6-SS Oscillation Arm Replacement
你所需要的
  1. Insignia NS-F12R6-SS Oscillation Arm Replacement, Front Cage: 步骤 1 中的图像 1,2 Insignia NS-F12R6-SS Oscillation Arm Replacement, Front Cage: 步骤 1 中的图像 2,2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 2 中的图像 1,1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 3 中的图像 1,1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Oscillation Arm Replacement, Fan Blade: 步骤 4 中的图像 1,1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 5 中的图像 1,1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Oscillation Arm Replacement, Back Cage: 步骤 6 中的图像 1,1
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 7 中的图像 1,1
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Button: 步骤 8 中的图像 1,2 Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Button: 步骤 8 中的图像 2,2
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 9 中的图像 1,1
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Oscillation Arm Replacement, Motor Housing: 步骤 10 中的图像 1,1
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 11 中的图像 1,1
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 12 中的图像 1,2 Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 12 中的图像 2,2
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 13 中的图像 1,1
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 14 中的图像 1,2 Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 14 中的图像 2,2
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 15 中的图像 1,1
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 16 中的图像 1,1
    • Remove the small piece of paper hanging on the power button.
  17. Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Arm: 步骤 17 中的图像 1,2 Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Arm: 步骤 17 中的图像 2,2
    • Using a Phillips #3 screwdriver, unscrew the the 16 mm long screw fastening the oscillation arm to the lower oscillation gear screw.
  18. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 18 中的图像 1,2 Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 18 中的图像 2,2
    • Using a Phillips #3 screwdriver, unscrew and remove the 4 mm long bolt on the front face of the base that fastens the motor assembly to the base bolt.
  19. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 19 中的图像 1,1
    • Remove the fan motor assembly from the base.
  20. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 20 中的图像 1,2 Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 20 中的图像 2,2
    • Using a Phillips #3 screwdriver, unscrew the 15 mm long bolt fastening the oscillation arm to the fan base bolt.
  21. Insignia NS-F12R6-SS Oscillation Arm Replacement: 步骤 21 中的图像 1,1
    • Remove the oscillation arm.
结论
另外一个人完成了本指南。
Hank
于09/17/18注册
1,091 声望
创作了8篇指南
团队
CSU Fullerton, Team S2-G1, Bruce Fall 2018 CSU Fullerton, Team S2-G1, Bruce Fall 2018 的会员
CSUF-BRUCE-F18S2G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 396
