跳转到主内容
Insignia NS-F12R6-SS Fan Blade Replacement
你所需要的
  1. Insignia NS-F12R6-SS Fan Blade Replacement, Front Cage: 步骤 1 中的图像 1,2 Insignia NS-F12R6-SS Fan Blade Replacement, Front Cage: 步骤 1 中的图像 2,2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Fan Blade Replacement: 步骤 2 中的图像 1,1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Fan Blade Replacement: 步骤 3 中的图像 1,1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Fan Blade Replacement, Fan Blade: 步骤 4 中的图像 1,1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Fan Blade Replacement: 步骤 5 中的图像 1,1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
结论
Hank
于09/17/18注册
1,142 声望
创作了8篇指南
团队
CSU Fullerton, Team S2-G1, Bruce Fall 2018 CSU Fullerton, Team S2-G1, Bruce Fall 2018 的会员
CSUF-BRUCE-F18S2G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 378
