跳转到主内容
Insignia NS-DS9PDVD15 Screen Replacement
你所需要的
  1. Insignia NS-DS9PDVD15  Screen Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Insignia NS-DS9PDVD15  Screen Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 2 中的图像 1,2 Insignia NS-DS9PDVD15  Screen Replacement: 步骤 2 中的图像 2,2
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 3 中的图像 1,1
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 4 中的图像 1,2 Insignia NS-DS9PDVD15  Screen Replacement: 步骤 4 中的图像 2,2
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 5 中的图像 1,3 Insignia NS-DS9PDVD15  Screen Replacement: 步骤 5 中的图像 2,3 Insignia NS-DS9PDVD15  Screen Replacement: 步骤 5 中的图像 3,3
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15  Screen Replacement, Disc Tray: 步骤 6 中的图像 1,2 Insignia NS-DS9PDVD15  Screen Replacement, Disc Tray: 步骤 6 中的图像 2,2
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 7 中的图像 1,1
    • Slide the tray up and off of the hinge completely.
  8. Insignia NS-DS9PDVD15  Screen Replacement, Screen: 步骤 8 中的图像 1,1
    • After the bottom cover and disk tray have been removed, remove the back panel from the top half.
    • There are six, 9 mm screws on the bottom cover and 2 screws on the hinge. Remove them with the JIS #000 screwdriver.
  9. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 9 中的图像 1,2 Insignia NS-DS9PDVD15  Screen Replacement: 步骤 9 中的图像 2,2
    • Once all the screws are removed, pry off the cover with the pry tool.
    • You'll see the PC board, back of the speakers, and the back of the screen.
  10. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 10 中的图像 1,2 Insignia NS-DS9PDVD15  Screen Replacement: 步骤 10 中的图像 2,2
    • Remove the ribbon cable carefully with the pry tool.
    • First, push out the black portion.
  11. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 11 中的图像 1,2 Insignia NS-DS9PDVD15  Screen Replacement: 步骤 11 中的图像 2,2
    • Next, push out the 'ribbon' with the pry tool.
  12. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 12 中的图像 1,2 Insignia NS-DS9PDVD15  Screen Replacement: 步骤 12 中的图像 2,2
    • Unscrew the corners of screen with the JIS #000 screwdriver. There are four, 6 mm screws with washers.
  13. Insignia NS-DS9PDVD15  Screen Replacement: 步骤 13 中的图像 1,2 Insignia NS-DS9PDVD15  Screen Replacement: 步骤 13 中的图像 2,2
    • After the screws and washers are removed, you can lift the screen off with the pry tool.
结论
一条评论
what is the model of the LCD Panel?
Justin Frost - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 696
