跳转到主内容
Insignia NS-D160A14 Motherboard Replacement
你所需要的
  1. Insignia NS-D160A14 Motherboard Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Unplug the power cord before proceeding to open the DVD player's enclosure.
    • Remove the two 7mm Phillips #2 screws from the back of the DVD player.
  2. Insignia NS-D160A14 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Carefully lift the outer case up, starting from the back.
    • Removing the outer case may require some force, and you will need to get the case into an angled position compared to the rest of the DVD player before it can be completely separated.
  3. Insignia NS-D160A14 Motherboard Replacement, Front Panel: 步骤 3 中的图像 1,3 Insignia NS-D160A14 Motherboard Replacement, Front Panel: 步骤 3 中的图像 2,3 Insignia NS-D160A14 Motherboard Replacement, Front Panel: 步骤 3 中的图像 3,3
    • Unhook the 4 hooks on the main casing.
    • There is one hook on the top of the casing, one on the bottom, and one on each side.
    • These hooks are brittle and can easily break.
  4. Insignia NS-D160A14 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Remove the central 7 mm screw holding the motherboard in place.
    • Be sure to ground yourself before manipulating the motherboard. A static shock could render one or more components on the motherboard useless.
  5. Insignia NS-D160A14 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Disconnect the white power cord connector from the motherboard.
  6. Insignia NS-D160A14 Motherboard Replacement: 步骤 6 中的图像 1,2 Insignia NS-D160A14 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Keeping the 8-pin connector as straight as possible, lift the motherboard out of case.
    • You may need to bend the side of the case slightly to give the motherboard room to be lifted out.
结论
另外一个人完成了本指南。
Ian Hanken
于07/20/16注册
516 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 11
总计 955
