跳转到主内容
Insignia NS-CSPBTHOL-R Battery Replacement
你所需要的
  1. Insignia NS-CSPBTHOL-R Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
    • Angle the spudger to create a separation between the grate and the base.
  2. Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 2 中的图像 1,1
    • Slide the spudger along the separation between the grate and the base of the speaker to loosen the grate. Do this to the entire perimeter of the speaker.
  3. Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 3 中的图像 1,2 Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 3 中的图像 2,2
    • Pull the grated panel off.
  4. Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 4 中的图像 1,2 Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  5. Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 5 中的图像 1,2 Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 5 中的图像 2,2
    • Push the spudger into the crevice between the base and the face of the speaker and create a separation.
    • Slide the spudger along the entire perimeter and gently pull off the face of the speaker.
    • The two parts are connected by wires, do not rip them apart.
  6. Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 6 中的图像 1,1
    • Use the spudger to release the battery by sliding it underneath the battery to create a separation.
    • Remove the battery.
  7. Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 7 中的图像 1,2 Insignia NS-CSPBTHOL-R Battery Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Pull the motherboard from the base of the speaker.
    • Using tweezers, squeeze and pull on the white plastic clip that connects the battery wires to the motherboard.
    • Unclip the battery from the motherboard.
结论
4等其他人完成本指南。
Judith Villegas
于02/15/17注册
312 声望
创作了2篇指南
团队
USF Tampa, Team 12-6, Eyestone Spring 2017 USF Tampa, Team 12-6, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G6
3 名成员
创作了4篇指南
4条评论
excellent, was able to make my Insignia speaker work, which didn’t work for years. The battery had been good. removing and reassembling made the unit work!
Uthayaraj - 回复
What type of battery does it use?
Michelle McFadden - 回复
Did you ever find out what battery it takes?
Steve Skinner -
I found out the correct replacement battery is 18650, 3.7V/2000mAH
Steve Skinner -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 2,370
