跳转到主内容
Insignia NS-CLOPP2 Screen Replacement
你所需要的
  1. Insignia NS-CLOPP2 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
  2. Insignia NS-CLOPP2 Screen Replacement: 步骤 2 中的图像 1,1
    • Begin to pry the front screen off gently with a Jimmy tool made by Ifixit.
  3. Insignia NS-CLOPP2 Screen Replacement: 步骤 3 中的图像 1,1
    • Once you are able to create a space in between the device and the front screen, use your hands to continue to pry off the screen. Make sure that all the mini latches surrounding the perimeter have been unlatched, allowing the screen to come off easily.
  4. Insignia NS-CLOPP2 Screen Replacement: 步骤 4 中的图像 1,1
    • Once you have undone the latches and pried off the first half of the screen, use your hand to pull off the rest of the screen.
    • To reassemble your device, follow these instructions in reverse order.
结论
2等其他人完成本指南。
Dilini De Silva
于03/11/15注册
757 声望
创作了5篇指南
团队
Marist, Team 1-1, Laflen Spring 2015 Marist, Team 1-1, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G1
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 225
