跳转到主内容
Insignia NS-CLOPP2 Motherboard Replacement
你所需要的
  1. Insignia NS-CLOPP2 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • First, remove the front screen. (See prerequisite screen removal guide.)
  2. Insignia NS-CLOPP2 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to gently pry the motherboard forward and away from the rest of the device.
  3. Insignia NS-CLOPP2 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Gently lift the motherboard up and out, making sure that you don't disassemble any of the wires in place by pulling too hard.
  4. Insignia NS-CLOPP2 Motherboard Replacement: 步骤 4 中的图像 1,1
    • To fully remove the motherboard from the clock, use wire cutters to carefully sever the connections between the motherboard and the wires attached.
    • To reassemble your device, follow these instructions in reverse order.
结论
3等其他人完成本指南。
Dilini De Silva
于03/11/15注册
757 声望
创作了5篇指南
团队
Marist, Team 1-1, Laflen Spring 2015 Marist, Team 1-1, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G1
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 145
