跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement
你所需要的
  1. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement, Power Auxiliary Port Replacement: 步骤 1 中的图像 1,1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 2 中的图像 1,1
    • Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
  3. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 3 中的图像 1,1
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 4 中的图像 1,1
    • Using a plastic spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 5 中的图像 1,1
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 6 中的图像 1,1
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 7 中的图像 1,1
    • Once you peel of the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 8 中的图像 1,1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 9 中的图像 1,1
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 10 中的图像 1,1
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 11 中的图像 1,1
    • Begin with remove the plug to your left.
  12. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 12 中的图像 1,1
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 13 中的图像 1,1
    • Remove the plug in the front of the lcd screen plug.
  14. Insignia NS-CLIP02 Power Auxiliary Port Replacement Replacement: 步骤 14 中的图像 1,1
    • Remove the LCD screen plug last. Then, follow the following instructions in reverse, replacing the old motherboard with the new one to fix the power auxiliary port.
结论
Erik
于02/19/15注册
405 声望
创作了4篇指南
团队
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 202
