跳转到主内容
Insignia NS-CLIP02 Digital Display Replacement
你所需要的
  1. Insignia NS-CLIP02 Digital Display Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Digital Display Replacement: 步骤 2 中的图像 1,2 Insignia NS-CLIP02 Digital Display Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Digital Display Replacement: 步骤 3 中的图像 1,2 Insignia NS-CLIP02 Digital Display Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Digital Display Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Digital Display Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Digital Display Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Digital Display Replacement: 步骤 7 中的图像 1,1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Digital Display Replacement: 步骤 8 中的图像 1,3 Insignia NS-CLIP02 Digital Display Replacement: 步骤 8 中的图像 2,3 Insignia NS-CLIP02 Digital Display Replacement: 步骤 8 中的图像 3,3
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Digital Display Replacement, Digital Display: 步骤 9 中的图像 1,1
    • Using the Phillips screwdriver, remove the three screws that run along the center of the base.
  10. Insignia NS-CLIP02 Digital Display Replacement: 步骤 10 中的图像 1,2 Insignia NS-CLIP02 Digital Display Replacement: 步骤 10 中的图像 2,2
    • Carefully remove the base.
  11. Insignia NS-CLIP02 Digital Display Replacement: 步骤 11 中的图像 1,2 Insignia NS-CLIP02 Digital Display Replacement: 步骤 11 中的图像 2,2
    • Using the metal spudger, gently lift the face plate away from the display.
  12. Insignia NS-CLIP02 Digital Display Replacement: 步骤 12 中的图像 1,1
    • Once the face plate is removed, use the Phillips screwdriver to remove the six screws shown here.
  13. Insignia NS-CLIP02 Digital Display Replacement: 步骤 13 中的图像 1,2 Insignia NS-CLIP02 Digital Display Replacement: 步骤 13 中的图像 2,2
    • Using the metal spudger, lift the speaker grilles from the display.
    • The speaker grilles will hinge on the side closest to the display.
  14. Insignia NS-CLIP02 Digital Display Replacement: 步骤 14 中的图像 1,1
    • Using the Phillips screwdriver, remove the four screws shown here.
  15. Insignia NS-CLIP02 Digital Display Replacement: 步骤 15 中的图像 1,2 Insignia NS-CLIP02 Digital Display Replacement: 步骤 15 中的图像 2,2
    • The two pieces of the display should easily separate.
  16. Insignia NS-CLIP02 Digital Display Replacement: 步骤 16 中的图像 1,1
    • Using the Phillips screwdriver, remove the three screws shown here.
  17. Insignia NS-CLIP02 Digital Display Replacement: 步骤 17 中的图像 1,3 Insignia NS-CLIP02 Digital Display Replacement: 步骤 17 中的图像 2,3 Insignia NS-CLIP02 Digital Display Replacement: 步骤 17 中的图像 3,3
    • The digital display should now be easy to remove.
    • Replace with new part.
结论
Aubrey
于02/24/15注册
214 声望
创作了2篇指南
团队
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015 的会员
USFT-LEAHY-W15S9G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 471
