跳转到主内容
Insignia NS-B2110 Battery Replacement
你所需要的
  1. Insignia NS-B2110 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Insignia NS-B2110 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Battery Replacement: 步骤 2 中的图像 1,2 Insignia NS-B2110 Battery Replacement: 步骤 2 中的图像 2,2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
结论
Daniel Hodges
于10/14/13注册
301 声望
创作了3篇指南
团队
Cal Poly, Team 4-31, Amido Fall 2013 Cal Poly, Team 4-31, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G31
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 349
