跳转到主内容
简介
This guide will take you through the process of replacing speakers in an Insignia TV.
  1. Place the TV face down so you have access to the back.
    • Place the TV face down so you have access to the back.
  2. Rest the TV on its top edge so you have access to the base. Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base. Remove the base from the frame.
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
    • Remove the base from the frame.
  3. Lay the TV face down again. Use the Phillips 00 Screwdriver to remove all the Phillips Head Screws from the the backside of the TV.
    • Lay the TV face down again.
    • Use the Phillips 00 Screwdriver to remove all the Phillips Head Screws from the the backside of the TV.
  4. Stand the TV on its top edge.
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV. The two halves should pull apart easily since there are no longer any screws holding it together.
  5. There are wires still connecting the two halves, so remove all the pieces of tape to detach the wires from both sides. There are wires still connecting the two halves, so remove all the pieces of tape to detach the wires from both sides. There are wires still connecting the two halves, so remove all the pieces of tape to detach the wires from both sides.
    • There are wires still connecting the two halves, so remove all the pieces of tape to detach the wires from both sides.
  6. You should now be able to completely pry apart your TV so that you have a clear view of the inside on both sides.
    • You should now be able to completely pry apart your TV so that you have a clear view of the inside on both sides.
  7. Unplug the red (right speaker) cord from the motherboard. Unplug the white (left speaker) cord from the motherboard.
    • Unplug the red (right speaker) cord from the motherboard.
    • Unplug the white (left speaker) cord from the motherboard.
  8. Start by locating speaker in bottom of back panel.
    • Start by locating speaker in bottom of back panel.
  9. Remove screws on both sides holding the speaker in place.
    • Remove screws on both sides holding the speaker in place.
  10. Pull the speaker out of its casing, and repeat for the process for the other speaker.
    • Pull the speaker out of its casing, and repeat for the process for the other speaker.
结论
Hannah Berenjfoorosh
于2018年01月22日注册
491 信誉积分
创作了3篇指南
团队
Cal Poly, Team S16-G2, Banghart Winter 2018 Cal Poly, Team S16-G2, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G2
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 13
总计 483
