跳转到主内容
Insignia NS-24ER310NA17 Motherboard Replacement
你所需要的
  1. Insignia NS-24ER310NA17 Motherboard Replacement, Insignia NS-24ER310NA17: 步骤 1 中的图像 1,3 Insignia NS-24ER310NA17 Motherboard Replacement, Insignia NS-24ER310NA17: 步骤 1 中的图像 2,3 Insignia NS-24ER310NA17 Motherboard Replacement, Insignia NS-24ER310NA17: 步骤 1 中的图像 3,3
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to remove the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 2 中的图像 1,3 Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 2 中的图像 2,3 Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Motherboard Replacement, Pry the TV open: 步骤 3 中的图像 1,1
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Motherboard Replacement, Disconnect wires: 步骤 4 中的图像 1,3 Insignia NS-24ER310NA17 Motherboard Replacement, Disconnect wires: 步骤 4 中的图像 2,3 Insignia NS-24ER310NA17 Motherboard Replacement, Disconnect wires: 步骤 4 中的图像 3,3
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
  6. Insignia NS-24ER310NA17 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove all strips of tape attached to the silver steel rectangular piece.
  7. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pull the red wire out from under the black plastic clip.
  8. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 8 中的图像 1,2 Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Unscrew the four screws surrounding the steel rectangle with a Phillips 00 Screwdriver.
  9. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Carefully lift the rectangular piece.
  10. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 10 中的图像 1,1
    • The rectangular piece will still be attached to the motherboard beneath it with a strip of tape. Remove this strip of tape.
  11. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 11 中的图像 1,2 Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the two screws on both sides of the motherboard.
  12. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Carefully lift the motherboard away from the television.
    • Keep in mind that the motherboard is still attached by several thin wires and should not be tugged.
  13. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 13 中的图像 1,3 Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 13 中的图像 2,3 Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 13 中的图像 3,3
    • There are 5 wires attached to the motherboard. Remove the two thicker white wires to the right of the red wire.
  14. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 14 中的图像 1,3 Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 14 中的图像 2,3 Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Remove the remaining three wires from the mainboard.
  15. Insignia NS-24ER310NA17 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Carefully remove the mainboard from the television.
    • You have now successfully removed the mainboard.
结论
6等其他人完成本指南。
Maggie Kuntz
于01/22/18注册
301 声望
撰写一个指南
团队
Cal Poly, Team S16-G2, Banghart Winter 2018 Cal Poly, Team S16-G2, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G2
4 名成员
创作了6篇指南
一条评论
Did all said including main board replace still no picture
d k - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 62
总计 12,141
