跳转到主内容
Insignia NS-24ER310NA17 Disassembly
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Insignia NS-24ER310NA17 Disassembly, Remove the base: 步骤 1 中的图像 1,3 Insignia NS-24ER310NA17 Disassembly, Remove the base: 步骤 1 中的图像 2,3 Insignia NS-24ER310NA17 Disassembly, Remove the base: 步骤 1 中的图像 3,3
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Disassembly: 步骤 2 中的图像 1,3 Insignia NS-24ER310NA17 Disassembly: 步骤 2 中的图像 2,3 Insignia NS-24ER310NA17 Disassembly: 步骤 2 中的图像 3,3
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the Phillips Head Screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Disassembly, Pry the TV open: 步骤 3 中的图像 1,1
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Disassembly, Disconnect wires: 步骤 4 中的图像 1,3 Insignia NS-24ER310NA17 Disassembly, Disconnect wires: 步骤 4 中的图像 2,3 Insignia NS-24ER310NA17 Disassembly, Disconnect wires: 步骤 4 中的图像 3,3
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Disassembly: 步骤 5 中的图像 1,1
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
结论
团队
Cal Poly, Team S16-G2, Banghart Winter 2018 Cal Poly, Team S16-G2, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 42
