跳转到主内容
Insignia Flex 8 NS-P16AT08 Speakers Replacement
你所需要的
  1. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: 步骤 1 中的图像 1,3 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: 步骤 1 中的图像 2,3 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: 步骤 1 中的图像 3,3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Speakers Replacement: 步骤 2 中的图像 1,1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: 步骤 3 中的图像 1,2 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: 步骤 3 中的图像 2,2
    • There are two connections that attach the speakers to the motherboard.
    • Unplug the cables from the motherboard by gently pulling them away.
    • Speaker cables will be free to be removed.
  4. Insignia Flex 8 NS-P16AT08 Speakers Replacement: 步骤 4 中的图像 1,2 Insignia Flex 8 NS-P16AT08 Speakers Replacement: 步骤 4 中的图像 2,2
    • Remove the tape that is holding the speaker cables down.
    • Remove the speaker cables from underneath the black connector ribbons.
    • The cables are hooked underneath black connector ribbons; carefully unhook them.
  5. Insignia Flex 8 NS-P16AT08 Speakers Replacement: 步骤 5 中的图像 1,1
    • Gently pry both speakers away from adhesive with metal spudger tool.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • The speakers can now be completely removed from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 6
总计 214
