简介
This replacement guide will help you to remove and replace the cameras in your Insignia Flex 8 tablet. If your front or back-facing cameras are not working, or the photos are blurry, replacing the camera(s) may be the best way to fix this problem.
你所需要的
Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
Gently peel all of the tape that is covering the cable connections going to and from the cameras. Set the tape aside for later reassembly.
