跳转到主内容
Insignia Flex 8 NS-P16AT08 Cameras Replacement
你所需要的
  1. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: 步骤 1 中的图像 1,3 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: 步骤 1 中的图像 2,3 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: 步骤 1 中的图像 3,3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 步骤 2 中的图像 1,1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Cameras: 步骤 3 中的图像 1,1
    • Gently peel all of the tape that is covering the cable connections going to and from the cameras. Set the tape aside for later reassembly.
  4. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 步骤 4 中的图像 1,2 Insignia Flex 8 NS-P16AT08 Cameras Replacement: 步骤 4 中的图像 2,2
    • Locate camera ribbon connector.
    • Using finger flip up black flap of camera ribbon connector.
  5. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 步骤 5 中的图像 1,1
    • Gently pull camera connector ribbon by hand until it separates from connector.
  6. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 步骤 6 中的图像 1,1
    • Using metal spudger tool, gently pry right speaker away from adhesive.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • Move right speaker to left side of device so you can freely access the camera ribbon.
  7. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 步骤 7 中的图像 1,1
    • Using metal spudger tool, gently pry the rear-facing camera from the adhesive.
  8. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 步骤 8 中的图像 1,1
    • Lift up connector ribbon that is attached to the cameras.
    • Slide cameras and connector ribbon out from underneath the speaker cords and battery.
  9. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 步骤 9 中的图像 1,1
    • Remove connector ribbon and cameras from device casing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 7
总计 226
