跳转到主内容
Insignia Flex 8 NS-P16AT08 Back Casing Replacement
你所需要的
  1. Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: 步骤 1 中的图像 1,3 Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: 步骤 1 中的图像 2,3 Insignia Flex 8 NS-P16AT08 Back Casing Replacement, Back Casing: 步骤 1 中的图像 3,3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Back Casing Replacement: 步骤 2 中的图像 1,1
    • Lift the back casing away from the screen.
    • Set casing aside.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 7
过去 30 天: 10
总计 606
