跳转到主内容
Insignia Flex 11.6 Speakers Replacement
你所需要的
  1. Insignia Flex 11.6 Speakers Replacement, Power Removal: 步骤 1 中的图像 1,3 Insignia Flex 11.6 Speakers Replacement, Power Removal: 步骤 1 中的图像 2,3 Insignia Flex 11.6 Speakers Replacement, Power Removal: 步骤 1 中的图像 3,3
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Speakers Replacement: 步骤 2 中的图像 1,2 Insignia Flex 11.6 Speakers Replacement: 步骤 2 中的图像 2,2
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. 如何卸下滑丝的螺丝
  3. Insignia Flex 11.6 Speakers Replacement: 步骤 3 中的图像 1,3 Insignia Flex 11.6 Speakers Replacement: 步骤 3 中的图像 2,3 Insignia Flex 11.6 Speakers Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Speakers Replacement: 步骤 4 中的图像 1,3 Insignia Flex 11.6 Speakers Replacement: 步骤 4 中的图像 2,3 Insignia Flex 11.6 Speakers Replacement: 步骤 4 中的图像 3,3
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Remove 2 electrical connectors that connects to the speaker using flat tweezers.
  6. Insignia Flex 11.6 Speakers Replacement: 步骤 6 中的图像 1,2 Insignia Flex 11.6 Speakers Replacement: 步骤 6 中的图像 2,2
    • Remove 2 - 6 mm J000 Phillips screws from each of the speakers.
    • Speakers will pop out at this point.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 515
