跳转到主内容
Insignia Flex 11.6 Screen Replacement
你所需要的
  1. Insignia Flex 11.6 Screen Replacement, Power Removal: 步骤 1 中的图像 1,3 Insignia Flex 11.6 Screen Replacement, Power Removal: 步骤 1 中的图像 2,3 Insignia Flex 11.6 Screen Replacement, Power Removal: 步骤 1 中的图像 3,3
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Screen Replacement: 步骤 2 中的图像 1,2 Insignia Flex 11.6 Screen Replacement: 步骤 2 中的图像 2,2
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. 如何卸下滑丝的螺丝
  3. Insignia Flex 11.6 Screen Replacement: 步骤 3 中的图像 1,3 Insignia Flex 11.6 Screen Replacement: 步骤 3 中的图像 2,3 Insignia Flex 11.6 Screen Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Screen Replacement: 步骤 4 中的图像 1,3 Insignia Flex 11.6 Screen Replacement: 步骤 4 中的图像 2,3 Insignia Flex 11.6 Screen Replacement: 步骤 4 中的图像 3,3
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Screen Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Unplug the 2 speaker's connection from the motherboard.
  6. Insignia Flex 11.6 Screen Replacement: 步骤 6 中的图像 1,2 Insignia Flex 11.6 Screen Replacement: 步骤 6 中的图像 2,2
    • Peel the yellow tape off from on top of the electrical connectors.
  7. Insignia Flex 11.6 Screen Replacement: 步骤 7 中的图像 1,2 Insignia Flex 11.6 Screen Replacement: 步骤 7 中的图像 2,2
    • Flip up the black cover pieces to expose the 3 electrical connectors.
    • Remove 3 electrical connectors by gently pulling back on them with some tweezers.
  8. Insignia Flex 11.6 Screen Replacement: 步骤 8 中的图像 1,3 Insignia Flex 11.6 Screen Replacement: 步骤 8 中的图像 2,3 Insignia Flex 11.6 Screen Replacement: 步骤 8 中的图像 3,3
    • Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
    • Remove the black camera connector by gently prying on it until it unhooks.
  9. Insignia Flex 11.6 Screen Replacement: 步骤 9 中的图像 1,2 Insignia Flex 11.6 Screen Replacement: 步骤 9 中的图像 2,2
    • Using tweezers, remove the microphone from the the plastic cover.
  10. Insignia Flex 11.6 Screen Replacement: 步骤 10 中的图像 1,1
    • Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
    • Motherboard pops out.
  11. Insignia Flex 11.6 Screen Replacement, Screen: 步骤 11 中的图像 1,3 Insignia Flex 11.6 Screen Replacement, Screen: 步骤 11 中的图像 2,3 Insignia Flex 11.6 Screen Replacement, Screen: 步骤 11 中的图像 3,3
    • Remove battery by prying off with card.
  12. Insignia Flex 11.6 Screen Replacement: 步骤 12 中的图像 1,2 Insignia Flex 11.6 Screen Replacement: 步骤 12 中的图像 2,2
    • Peel back the copper color electrical connector with blue opening tool.
  13. Insignia Flex 11.6 Screen Replacement: 步骤 13 中的图像 1,1
    • Remove 12 - 4.15mm J000 Phillips screws from the metal bracket.
    • Bracket will then come off.
  14. Insignia Flex 11.6 Screen Replacement: 步骤 14 中的图像 1,1
    • Remove 1 - 3.4 mm J000 Phillips screw from metal plate bracket.
  15. Insignia Flex 11.6 Screen Replacement: 步骤 15 中的图像 1,2 Insignia Flex 11.6 Screen Replacement: 步骤 15 中的图像 2,2
    • Remove screen from case by prying with a card.
结论
4等其他人完成本指南。
6条评论
The Flex 11.6" Model# NS-P11W7100 DOEST HAVE THOSE SCREWS RIGHT THERE!!!!!
Charles Kinnison - 回复
yeah, thats the one I have. its quite a bit different. the speaker wires are soldered, too…
Joshua Francis -
mine doesn’t look like that…
Joshua Francis - 回复
where can i get a new screen to buy?
florence sefaa - 回复
Do you sell the insignia ns-p11w7100 tablet 11.6 inches screen? I need on to fix my broken part.
florence sefaa - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 4,463
