跳转到主内容
Insignia Flex 11.6 Motherboard Replacement
你所需要的
  1. Insignia Flex 11.6 Motherboard Replacement, Power Removal: 步骤 1 中的图像 1,3 Insignia Flex 11.6 Motherboard Replacement, Power Removal: 步骤 1 中的图像 2,3 Insignia Flex 11.6 Motherboard Replacement, Power Removal: 步骤 1 中的图像 3,3
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Place the device on a firm surface with the device screen facing down.
  2. Insignia Flex 11.6 Motherboard Replacement: 步骤 2 中的图像 1,2 Insignia Flex 11.6 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove 2, 6.1 mm Phillips J000 screws from the back of the device.
    • If any screws are stripped, refer to the ifixit guide for how to remove a stripped screw. 如何卸下滑丝的螺丝
  3. Insignia Flex 11.6 Motherboard Replacement: 步骤 3 中的图像 1,3 Insignia Flex 11.6 Motherboard Replacement: 步骤 3 中的图像 2,3 Insignia Flex 11.6 Motherboard Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Using a plastic tool and the plastic card, gently pry off the back cover.
  4. Insignia Flex 11.6 Motherboard Replacement: 步骤 4 中的图像 1,3 Insignia Flex 11.6 Motherboard Replacement: 步骤 4 中的图像 2,3 Insignia Flex 11.6 Motherboard Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Unplug the 2 speaker's connection from the motherboard.
  6. Insignia Flex 11.6 Motherboard Replacement: 步骤 6 中的图像 1,2 Insignia Flex 11.6 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Peel the yellow tape off from on top of the electrical connectors.
  7. Insignia Flex 11.6 Motherboard Replacement: 步骤 7 中的图像 1,2 Insignia Flex 11.6 Motherboard Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Flip up the black cover pieces to expose the 3 electrical connectors.
    • Remove 3 electrical connectors by gently pulling back on them with some tweezers.
  8. Insignia Flex 11.6 Motherboard Replacement: 步骤 8 中的图像 1,3 Insignia Flex 11.6 Motherboard Replacement: 步骤 8 中的图像 2,3 Insignia Flex 11.6 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Unplug the 2 black ground wires from the motherboard by gently prying on them until they unhook from the motherboard.
    • Remove the black camera connector by gently prying on it until it unhooks.
  9. Insignia Flex 11.6 Motherboard Replacement: 步骤 9 中的图像 1,2 Insignia Flex 11.6 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Using tweezers, remove the microphone from the the plastic cover.
  10. Insignia Flex 11.6 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove 5 - 3.4 mm Phillips J000 screws from the motherboard.
    • Motherboard pops out.
结论
2等其他人完成本指南。
2条评论
This looks great. Can you provide more detail on Step 3 (opening the case?) Are there locking tabs that I need to worry about breaking? And if so, how many? Does the cover simply snap back into place?
I need to open my unit simply to disconnect the power to clear the BIOS. I stupidly disabled my USB ports and there is no way to navigate the BIOS without the (USB) keyboard (how freaking dumb is that!)
Mugsys RapSheet - 回复
Very nicely done. Do you suppose that the SSD can be upgraded to something larger?
Curtiss Riedel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 2,463
