简介
If your Insignia Flex 11.6 is not holding a charge or is not starting up, use this guide in replacing the battery.
你所需要的
Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand.
The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device.
5等其他人完成本指南。
6条评论
There are no screws on the bottom edge of my invicta model P11A8100. Can I bypass removing screws and proceed to removing the back?
There are no screws on the bottom of my model P11A8100. Can I bypass removal is said screws and proceed to opening the back?
Great instructions but I cant find a battery replacement. Battery number 3394122-2p
Great instructions but now I cant find the battery anywhere it is 3394122-2p
