跳转到主内容
Insignia Flex 10.1 NS-P16AT10 Camera Replacement
你所需要的
  1. Insignia Flex 10.1 NS-P16AT10 Camera Replacement, Camera: 步骤 1 中的图像 1,2 Insignia Flex 10.1 NS-P16AT10 Camera Replacement, Camera: 步骤 1 中的图像 2,2
    • Make sure your device is off and not connected to any power sources to avoid injury
    • Use a plastic opening tool to remove the rear panel from the front case.
    • Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
    • The volume rocker and power button will become free from the device when the front and rear panels are separated from each other. Do not worry. These pieces are easily put back into place when reassembling the tablet.
  2. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 步骤 2 中的图像 1,2 Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 步骤 2 中的图像 2,2
    • Use a plastic opening tool to flip up the ribbon connector that connects the camera to the motherboard.
    • Free the ribbon cable from the motherboard.
  3. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 步骤 3 中的图像 1,2 Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 步骤 3 中的图像 2,2
    • Use a #00 Phillips head screw driver to remove the two screws that hold the camera down to the front case.
  4. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers or your fingers to remove the camera from your Insignia Flex 10.1 NS-P16AT10.
  5. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 步骤 5 中的图像 1,2 Insignia Flex 10.1 NS-P16AT10 Camera Replacement: 步骤 5 中的图像 2,2
    • The camera is now free and ready to be replaced.
结论
Morgan Kidd
于10/10/16注册
419 声望
创作了3篇指南
团队
Texas Tech, Team 12-3, Bennett Fall 2016 Texas Tech, Team 12-3, Bennett Fall 2016 的会员
TTU-BENNETT-F16S12G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 144
