跳转到主内容
Insignia Flex 10.1 NS-P10W8100 Camera Replacement
你所需要的
  1. Insignia Flex 10.1 NS-P10W8100 Camera Replacement, Camera: 步骤 1 中的图像 1,2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement, Camera: 步骤 1 中的图像 2,2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 2 中的图像 1,2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 2 中的图像 2,2
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to each side to help pry the back cover evenly.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 3 中的图像 1,1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off work your fingers around the corners and slowly pry the cover off using your fingers.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 4 中的图像 1,2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 4 中的图像 2,2
    • Carefully remove the yellow tape holding down the camera ribbon connector by pulling it upwards.
    • Remove the black tape holding down the camera ribbon connector which is attached to the motherboard.
  5. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 5 中的图像 1,2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 5 中的图像 2,2
    • Disconnect the zero insertion force (ZIF) connector by using your fingernail to flip the small locking flap.
    • Disconnect the cable by gently pulling it outward.
  6. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 6 中的图像 1,3 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 6 中的图像 2,3 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 步骤 6 中的图像 3,3
    • Remove the camera by pulling it upward.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 190
