跳转到主内容
Insignia 6-Quart Pressure Cooker Float Valve Replacement
  1. Insignia 6-Quart Pressure Cooker Float Valve Replacement, Float Valve: 步骤 1 中的图像 1,1
    • Remove the lid and place it upside-down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Float Valve Replacement: 步骤 2 中的图像 1,1
    • Pinch the rubber gasket on the float valve and pull up.
  3. Insignia 6-Quart Pressure Cooker Float Valve Replacement: 步骤 3 中的图像 1,2 Insignia 6-Quart Pressure Cooker Float Valve Replacement: 步骤 3 中的图像 2,2
    • Pull the rubber gasket off of the metal rod.
    • The valve will fall out of its hole onto the table. It can now be cleaned or replaced.
    • You may find it helpful to push up on the float valve from the other side of the lid while you remove the gasket.
结论
3等其他人完成本指南。
Savannah Webb
于01/18/18注册
657 声望
创作了5篇指南
团队
Cal Poly, Team S12-G3, Banghart Winter 2018 Cal Poly, Team S12-G3, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S12G3
4 名成员
创作了5篇指南
3条评论
I received the replacement valve and pot. Now my insignia instapot won't hold pressure. It keeps seeping steam/spritz out of the float valve. I am ready to toss it in the trash. It worked bafore I replaced that stem. I should've kept it.
Carole Neider - 回复
OK after much digging, I found the old valve and now it is pressurizing.
Carole Neider - 回复
where can I buy the float valves
valuacion.urbanismo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 78
总计 4,562
