简介
Circuit boards may require replacement after consistent use. This guide will show how to remove the circuit board.
你所需要的
Remove and replace the circuit board.
Its good to see repair details available to buyers /users.Some manufacturers keep that info under wraps. The instructions are clear and concise.I have a Kuppet Electric Pressure board that needs changing. The info and details can be applied to many products, thereby assisting buyers who are not fortunate to have this assistance.APPRECIATED
5等其他人完成本指南。
8条评论
Where do you purchase the circuit board
why is my circuit board not fixed to the top like in the diagram
where can I purchase the circuit board
I have an Instant Pot Duo Crisp 11-in-1 Air Fryer and Electric Pressure Cooker Combo. It doesn't power on I can e that the component on the PC board transient suppressor is burned up si I want to replace the control board. I can remove all the connections except the wide white connector with the 13 red wires on it. I've tried to pull in the connector but it won't budge. Any suggestions? The control board part number is.....MY-AIRFRY-PO2A VER: 1.0 2019-06-15
W:80mm L:112mm
I've even tried to use a pair of needle nose to pull the connector off and it won't budge it's almost like they soldered the connector to the board I'm hoping they didn't do that.
Let me know if you have any thoughts thanks Dave
muy buena la explicacion
Esta explicacion nos ayuda soluionar los problemas tecnicos que se presetan en nuevos productos .
Where can i buy a circuit board for a Kuppet pressure cooker.Board info—GT-YLG-TY-M01
malcolm reid - 回复
