跳转到主内容
Insignia 6-Quart Pressure Cooker Circuit Board Replacement
你所需要的
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: 步骤 1 中的图像 1,1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 8 中的图像 1,1
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 9 中的图像 1,1
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 10 中的图像 1,1
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 11 中的图像 1,1
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 12 中的图像 1,1
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 13 中的图像 1,1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 步骤 14 中的图像 1,1
    • Remove and replace the circuit board.
结论
5等其他人完成本指南。
Savannah Webb
于01/18/18注册
657 声望
创作了5篇指南
团队
Cal Poly, Team S12-G3, Banghart Winter 2018 Cal Poly, Team S12-G3, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S12G3
4 名成员
创作了5篇指南
8条评论
Where do you purchase the circuit board
Douglas Koons - 回复
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - 回复
Please, Where can I buy the electrical circuit?
Mohammed - 回复
why is my circuit board not fixed to the top like in the diagram
david stanley - 回复
where can I purchase the circuit board
de27@bellsouth.net - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 3,223
